Home  >>Trails >> United States Trails >>West Virginia >>
Login  |  Register
Options
Add a Trail
Latest Trail Reviews
Latest Trails Added
Report incorrect or duplicate trails here.
Review Policy
MtbREVIEW.com supports IMBA and responsible riding. Please submit only legal trails to our list. If you discover a trail posted on this site that is not open for public mountain biking, please email our IMBA friends at info@imba.com with detailed info. They'll help us remove the unauthorized trail from the site.
Click here for info about keeping our trails open.
Related Links
MTBR Passion Forum
Save the Trails Forum
Mountain Bike Product Reviews
Lat: Lng:
putnam county park
2 reviews
 4 of 5
This trail system is still being developed. The trails are marked but the trail markers are only on one side of the trees. Start at the trail head and start to follow the markers. Some of the newer trails are not marked yet but can be found off of the existing trails. You can get 5 miles of riding in on these trails once you figure them out. If you are driving through West Virginia on Interstate 64, the trails are about 6 miles from the Winfield Teays Valley exit, exit 39. All of the trails are on the hillside above the park.
post pictures of this trail >>
search for trail pictures >>
This trail doesn't have any Longitude and Latitude data for the map. Participate and drag the red marker to the correct location.
Enter a Starting Point (City, State, or Landmark)
[X]Cancel
Latitude
38.54303003513975
Longitude
-81.93114280700683
Trail Length
5
Trail Level
Trails for all skill levels
Trail Type
Singletrack
City/County
Eleanor
State/Territory/Province
WV
Zip/Postal Code
25070
Country
US
Web Address
Information Added By
Read the Reviews >>     Write a Review >>
Sort Reviews by:  Latest Review | Best Rating
Reviews 1 - 2 (2 Reviews Total)
Review Date
May 8, 2008
Overall Rating
 5 of 5
Aerobic Difficulty
 3 of 5
Technical Difficulty
 4 of 5
Ridden Trail:
Once a month
Rate this review?
Reviewed by: ovbc ,  Cross Country Rider
Summary:
I recently got to ride with some of the guys who built this trail. The Putnam boys deserve credit for hard work and a well thought out set of trails, they created a very nice base trail system that can be expanded for years. Signage is in it's infancy (like all new trail systems) but there are blazes if you can look up quick enough to see one as you head down a killer set of switchbacks or along the contour of a nice bench cut strewn with landscaping size sandstones.
The planned route and the one I rode was the future race course (WVMBA 08)or some variation of it. The length around 12+/- miles. The trail begins (I suppose the race also)on pavement then up a gravel road a short distance.. .. enough to spread a race bunch. Then entering left into singletrack, an uphill section of tight trail that keeps gaining as it contours, making various tight switchbacks until reaching a double track dirt road climb of several hundred feet of tough uphill with a fairly good dirt and stone surface. Once on top the trail turns double track and follows a gasline ROW for a distance then heads downhill quickly into a tricky little washed out road similiar to the one you just climbed. The rocks are larger and loose in the trail and the drainage forces you to weave your way back and forth across the drainage ruts. Pay attention. You might laugh a little bit at first and then suddenly find youself overskidding or slightly out of control for a second or two. Down a double track road for another distance then back into the woods for some more hand crafted singletrack. Very nice the main sections all countour, bench and then drop (or rise depending on direction), ditto and ditto with good flow. You can ride this fast if you are so technically inclined and it flows well enough to keep your heart rate from getting into the red. Actually my impression is that most all the trail I rode flowed really well. XC style technical bu also newly groomed and packing down. There are sections of tight squeezes and pedal reversals as you pass by encroaching rock outcroppings. Armouring is prevalent everywhere.. attention to detail, and several large log crossings keep things interesting. The greatest portion is singletrack and it's great. You end the ride approaching a larger than life sized Paul Bunyon and a whitewashed blue jean colored bull with a broken right horn. Good Ride!
Recommended Route:
Check out the TT blog and ask for a map or just follow arrows. Pay attention to your rights and lefts and it's all good and you won't get lost as long as you don't go far out of your way on a gasline ROW. Like I said if you pay attention you'll see where markers have been put up to help you along. This is a pretty new system so I'm sure marking is being masterminded.
Other recommended trails in the same area:
Within 50-60 miles
B'Ville Park
Bob Evans Farm
Kanawha State Forest
Kanawha Trace
Would you like to Comment?
Join MTBR.com for a free account, or Login if you are already a member.
Review Date
June 3, 2007
Overall Rating
 3 of 5
Aerobic Difficulty
 3 of 5
 3 of 5
Ridden Trail:
Once a month
Rate this review?
Reviewed by: NVA182 ,  Weekend Warrior
Summary:
Trail can be intense but within reason. The trail head is hard to find and I only know where it is because the guy who builds the trails showed me. It's 100% under trees so it's a nice reprieve from the summer sun.
Recommended Route:
There are different sections of the trail with varying difficulty. All are decently fun. Overall its pretty straight forward. You can easily finish in about an hour but if you have the intension of a leisurely pace you can make it last two hours.
I don't know any other trails in this area.
What's New
» Sea Otter Classic - Race and Cycling Festival
New products, race info, videos and more!»
You need Flash Player 8 (or higher) and JavaScript enabled to view this content
» Buy Mtbr Jerseys
Click here to view or buy the jersey and shorts.  Support Mtbr.com and order your set today.
View or buy
Mtbr Swag here»
Pro Reviews:
Photo Caption Contest
(sponsored by Maxxis)
Enter here
Advertise With Us | About Us | Contact Us | Privacy Policy | Terms Of Use The ConsumerREVIEW.com Network
 MtbREVIEW.com  RoadbikeREVIEW.com  OutdoorREVIEW.com
 PhotographyREVIEW.com  VideogameREVIEW.com  ComputingREVIEW.com
 AudioREVIEW.com  CarREVIEW.com  GolfREVIEW.com
Copyright ©1996-2008 All Rights Reserved.ConsumerREVIEW.com, a business unit of Invenda      RSS Feed
