MtbREVIEW.com supports IMBA and responsible riding. Please submit only legal
trails to our list. If you discover a trail posted on this site that is not
open for public mountain biking, please email our IMBA friends at
info@imba.com with detailed info.
They'll help us remove the unauthorized trail from the site.
Click here for info about keeping our trails open.
If this is the correct location, click "Save Point" below or type the nearest location (country, city, Zip, or land mark) and the map will pan over to the location if the location is found.
Save Point
Go to Nearest Location:
Lat:
Lng:
Mica Mountain
12 reviews
4.75 of 5
Anything your heart desires. From steep terrain to fireroads. Excellent up hill climb on main road or numerous logging roads. Steep downhill sections for those who know where to find them. Bring lots of water and enjoy getting lost in an area that not many know about--lesser known than Cannefield but even better than Beacon Hill.
Summary: Most trails are still covered in snow or deep mud (heavy runoff). Be good, and do the right thing by staying off the trails until they are dry and solid. We don't want to further wreck the trails - The way it looks now, we won't be able to make it to the Domes until July or August!!!
Would you like to Comment? Join MTBR.com for a free account, or Login if you are already a member.
Summary: My thanks to JPNuts (see above trail review) - The directions listed are spot on. The ride itself is awesome...A brutal climb, but so worth the effort. Be prepared for at least an hour or more of intense clibing. Fantastic views, a screaming downhill, and options for a truly epic all day ride. Be sure to bring plenty of water and tools as you will be at least 10 miles from help if something goes wrong.
Recommended Route: Start your ride at the "Climbing Wall" near the west boundary of the county park in Liberty Lake.
Other recommended trails in the same area: They are all connected, and generally start in the county park.
Summary: this is a very diverse trail system. steep ups and downs, water crossings, water falls, thin single track, fire roads, beautful views at the top. it is a all day trail if you choose to really explore.
Recommended Route: we chose to go up the water fall side, very steep technical climbing, even hike a bike spots. the "easy" side makes for a very fast down, it was a blast. once you get up to the first summit with the warm up shack you can climb even higher if you are feeling brave. we went clear to the summit of mica peak. it made for a long killer descend! we plan to go up the easier side next summer and attempt a fun, technical downhill ride.
Summary: This description keeps you on main trails allowing you to ride everything if you have the legs and lungs. 18 mile ride, 3720 feet elevation gain. great views from top.
Recommended Route: Drive I-90 to Liberty Lake exit. Go east on Mission (or Appleway?) to Moliter rd., turn South. Turn left on Valley Way, between the golf courses. Continue on this winding road. Stay left at the intersections. Pass the road on the right going down to county park (a variation to be discussed later). Climb past a water tank on the right and take the next right heading to the ORV park. Drive past the ORV parking lot and short while later pull into the horse parking lot. Park here.
Ride to Southeast corner of parking lot to find a single track heading downhill. Head down. Turn left at first intersection, and right at the second. Climb up a little hill and drop down again to the main double track which parallels Liberty Creek at 0.5 miles, turn left. (A right turn takes you into the campgrounds). Turn right (0.6) at first intersection, cross Liberty Creek on a bridge at 0.8 miles. Turn left at wooden wall and begin the leg burning climb. Stay on this well used wide trail, pass two right hand junctions, climbing over the water bars until at 1.9 miles an unsigned right fork appears; turn onto it. You have climbed about 800 feet so far. The climb backs off as the trail climbs and contours. At 2.9 this trail dumps out on a dirt road coming in from your right. Continue straight ahead to Y intersection just ahead. Go right and climb up to an old logging landing. Find the beat up trail heading up the hill from the landing. In about 1.1 miles intersect with a road coming in from your right. Go straight ahead. Continue on this washed out road, staying on the main trail, ignore the left hand turns. Keep at it until you break out in the open and there is the FAA radome enclosed in fence. You can turn around here or ride a little further South to see the views by turning right on the gravel road, and then left dropping down to another electronics installation. And do your gaping.Return back to the road you rode up on and ride downhill until you reach the previous landing 2.1 miles later. At the landing turn right on the beat up road that heads downhill continuing for 1.7 miles to a saddle at Round Mountain with several roads leading out from it. Take the left most road which goes over Kelly bumps and traverses Northwest over the Liberty Creek drainage. You are now riding on recent logging haul roads. Stay on this main road going over another set of Kelly bumps. At 1.5 miles find a sort of hidden wide trail dropping to your right. Hang on for the big water bars. Cross a creek and Kelly bumps and a smaller creek. Just pass this smaller creek follow the trail right to face the door of an outhouse. Turn right at the outhouse and left and drop onto an old road. Turn left and drop down into Liberty Creek 3.9 miles later. Stay straight at any intersections. Watch out for water bars and other trail users. The water bars you will find do more than divert water from trail. Soon you will pass the intersection where you turned right on your climb. The decent is sweeter than the climb out. Turn right at the wooden wall, cross Liberty Creek, and turn left onto main double track and continue till you find the trail on the right you rode down on. Take this, climb up back to the parking lot. Total ride 18.0 miles and 3750 elevation climbed.
Variation: Drive into Liberty Lake Regional Park, pay the entrance fee, drive back to the campground. At the Southern end park at a gate. Go thru the gate and in just 150 yards find the trail on the left coming down the hill from the upper free parking lot. At the end of the ride drive to the swimming area for a cooling off swim.
Review Date April 5, 2003
Overall Rating 5 of 5
Ridden Trail: Once a week
Visitors rate this review 2.00 of 5,
1 votes
Reviewed by: Dodgedog
, from Spokane WA
Summary: Great XC trail, a number one for a quick ride in my book. Starts out with a couple of climbs and flatens out a few places then back down the hill with a nice fast down hill and ends with a good cool down back to the lot. Trail is 95% single track and rocky some loose stuff. Moderate riders and up, the rocks can be a challenge. Recomended Clipless and front suspention. Frankie, Super Bee which way do we go... straight, left or right?
Recommended Route: Start at Appleway Toyota and ride up the sandy 4x4 trail on the right of the dirt road that takes you to the park. Don't go in the park! Go right! Loop trail thats about 5-9 miles diffrent routes, no maps, secret.
Other recommended trails in the same area: South hill, Riverside, Mini.
